NI_Excel.lvclass:Append Report Text(num).vi does not work reason unknown
Trying to Save the data with in my program. But all of the NI_ReportGeneration ToolKit does not work. have windows XP SP3 with all updates. Even down loaded the update code for LabVeiw2009 F3 still does not work.
(3,242 Views)
Does it give you an error?  Or is it just not appending the information to the report?  What version of Excel are you using? Any additional information that you have would be helpful.
I have attached a very simple example that should open Excel and write a string to the first cell.  What happens when you run this?
Justin Parker
Product Support Engineer
(3,230 Views)
You might need a licence for the Report Generation Toolkit. Check other erros to see if you also get something like this:
"This VI or item belongs to a library that is expired or invalidly licensed. Activate the license of the library to edit or run the VIs and items the library owns. For more information on activating this VI or item's owning library, see the error message on this VI or item's library."
(2,789 Views)
