NI FBUS V3.0
Hi
I am new on this industry trying to install ni fbus v3.0/01 configurator and communicator  software,after the softwere is loaded and try to connect it gives a massage that reads NIFBus cannot initialize an interface transport.. I tried several times to load it i am not sure what is coursing that fault.
(2,252 Views)
@Dikoma wrote:
Hi
You posted this in the wrong section.  The "Version Conversion" forum is for upgrading or downgrading the save version of VI files.  You need the general LabVIEW forum.  I flagged your post for a moderator to move this to the correct section.
With that in mind, I have not used FBUS, so I cannot reply directly to your question.  However when the thread gets moved, you will get help more quickly 😄
If someone helped you out, please select their post as the solution and/or give them Kudos!
(2,243 Views)
