NI HSDIO PXIe-6547 synchronization problem
Hi, I am new to Labview.
I am trying to control two HSDIO cards to generate digital signals.
I found some example codes in NI-library. (Fig.1)
In this example, They use for loop to merge the sessions signal(generate from niHSDIO get session VI) automatically.
My question is how can I combine the two session signals if I don't use a for loop function(Fig.2)?
(1,285 Views)
You just have to create an array of HSDIO session (of all cards that need to be synchronized) and feed into the TCLK API to synchronize
Santhosh
Soliton Technologies
(1,246 Views)
Thank you for your reply.
I successfully feed the secession signal into TCLK API.
But when I ran the vi program, the error occurred at niTCLK (shown as below).
Does anyone know the reason for this problem?
And how can I fix this bug?
Many thanks.
(1,229 Views)
Please share the code for review.
Santhosh
(1,215 Views)
Hi Santhosh,
Here is my code.
I use labview2018 and HSDIO 18.0
I appreciate your help.
(1,208 Views)
