NI HyperTrend
hi,
I am using the ActiveX component NI HyperTrend. Everytime I start the
program I have to manuelly define the scaling options for every trace.
To enforce the usabilty it would be great to store/read the HyperTrend
settings to/from a xml-file. Is it generally possible to manipulate
this activeX control?
Thanks for your help.
Joachim
(3,727 Views)
Hello Joachim,
Have you tried using the property and invoke node under application control pallette to get and set your NI Hypertrend's properties?
Daniel Keyser
"I reject your reality and substitute my own"
Adam Savage
"Mythbusters"
(3,579 Views)
Here is an example of what I mean. Unfortunately I have yet to get this to work, but perhaps this will be good food for thought.
Daniel Keyser
Adam Savage
"Mythbusters"
(3,564 Views)
FYI, the index needs to be incremented prior to changing it to a variant! I just found this out myself
Daniel Keyser
Adam Savage
"Mythbusters"
(3,554 Views)
