NI Hypertrend
Effective use of NI Hypertrend.
I am using Labview 7.1 with DSC modul and have limited experience using Labview, but hope to get ideas from the forum.
My problem is to use NI Hypertrend effectively. I have experience some problems with NI Hypertrend. From my experience it is not working properly if the NY hypertrend code is placed within a while loop. I have avoided this problem with creating the Hypertrend in a separate VI which is loaded from the Main program when the operator wants to see historical og real-time data. BUT the loading of the Hypertrend is VERY slow. It takes about 30 sec to 1 minute before the hypertrend can be used to check historical data stored using the DSC moduls tag-engine in the Citadel database.
How can I improve this, and make the code more efficient?
Like the code is written today the operator of the program needs to close the separate VI with the Hypetrend, add/ remove tags to plot in the Main.vi and load the separate VI with Hypertrend once again to have a updated NI Hypertrend plotting the desired values.
I really appreciate some help
Ingvald Bardsen
(3,218 Views)
Hello Ingvald!
Is your problem still an issue or has it been resolved?
Ashwani S.
National Instruments Sweden
(3,165 Views)
Hey Ashwani,
I had to replace the laptop that I used with the control system with a newer one due to "computer crash". Now it is defintely better! But I have not changed any code. Can you suggest any alternatives to control what Hypertrend should plot (real time data and historical data) during run?
Ingvald Bårdsen
Process Engineer
ProPure
(3,151 Views)
