NI-IMAQ 1394 image display
I'm a beginner in Labview and I'm trying to build a VI that displays an image snapped with a camera connected to an IEEE 1394 board. The problem is that the type of the image out output of IMAQ IEEE 1394 functions is not the same as the one of the other imaq functions and the image display indicator.
How can I convert it in order to use IMAQ IEEE 1394 functions with other IMAQ functions such as IMAQcreate for instance?
Thank you for your help !
(3,168 Views)
VanessaB wrote:
> Hello,
What versions of LabVIEW and IMAQ IEEE-1394 are you using? The IMAQ
handle has changed between LabVIEW 6.1 and 7.0 and if you are not using
the versions of the VI libraries to match your LabVIEW version you may
have some troubles.
Rolf K
(3,168 Views)
I use Labview 7.0 and NI-IMAQ IEEE 1394 1.1.
Thank you for your answer, I,m going to see if there is a newer version for the NI IMAQ.
(3,168 Views)
Hello Vanessa,
You must install the newest version of NI-IMAQ IEEE 1394 1.5.1.
You can do that for free by downloading it from : www.alliancevision.com.
Use the part Number : 850 413 E-03
Sanaa TAZI
Application Engineer
(3,168 Views)
I didn't manage to find where to download the driver on this website ( I subscribe to the technical support but the driver is not there ). Could you give me the complete URL ?
thank you very much !
(3,168 Views)
To download the driver, you should pass by the technical support of Alliance VISION.
So, in the web site, go to "Support technique" and click on "Ask question". There, you can ask the engineers to provide you the driver of your device.
Sanaa TAZI
(3,168 Views)
