Hello Warren,
Thank you for using our discussion forums. I have taken a look at your VI and seen similar behavior as you described. I noticed that if you remove the bundle by name from the case structure the problem seems to disappear, let me know if you see a similar behavior. Otherwise, I am trying to investigate the problem and will get back with you as soon as I have any updates. Thank you for your patience and have a great day!
Nipun M
