NI-IMAQ for USB 1.1.1 will not install with LV8 and Vision 8.0 or 8.21
When I try to install NI-IMAQ for USB 1.1.1 I get a message that vision 7.1 or higher with  Labview 7.0 or higher;  or Vision Assistant 7.1 or higher is required, I have tried the vision 8.0  and vision 8.2.1 packs with Labview 8.0 with no success.
(2,983 Views)
Hello mcg,
I am not familiar with NI-IMAQ for USB 1.1.1.
You are correct that you need LabVIEW 8.0 and Vision 8.0 installed.  After this you should be able to install this very simply.  If that's still giving you trouble, try repairing LabVIEW and repairing Vision (Start » Control Panel » Add or Remove Programs » National Instruments Software » LabVIEW or Vision » Repair).
Please let us know if you have any more trouble on this.  Please post a screenshot of the error as well.
Luke H
(2,968 Views)
