NI-IMAQ for USB appears in Vision Assistant, but not LabVIEW
I have NI-IMAQ for USB available in Vision Assistant 7.1, but it does not appear in LabVIEW 8.0.   I installed the NI-IMAQ for USB after LabVIEW 7.1 and then later upgraded to LabVIEW 8.0.  I was working with the images from the USB (DirectX) camera in Vision Assistant, but when I went to acquire images in LabVIEW 7.1 (per the included documentation), they were not in the Functions->NI-Measurements->Vision (which is completely empty).  In LabVIEW 8.0, I could not find the camera under any catagory, nor could I use "Select a VI..." and find any VI's in C:\Program Files\National Instruments\NI-IMAQ for USB.
(3,004 Views)
This maybe related to this link
http://forums.ni.com/ni/board/message?board.id=170&message.id=158980
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(2,991 Views)
Skeeter02,
It sounds like you need to reinstall your IMAQ for USB driver.  That should solve your problem.  I currently have the IMAQ USB driver working in LabVIEW 8.  If you did not install the IMAQ USB driver after installing LabVIEW 8 it will not work in LabVIEW 8.
I hope this helps,
Lorne Hengst
Application Engineer
(2,977 Views)
Thanks for your responses,  here is how I solved the problem.
I uninstalled the NI-Vision Development System and NI-IMAQ for USB,  Then re-installed NI-Vision Development, re-installed NI-IMAQ for USB, and finally ran a program called VisUtil.exe.  This  made the USB camera appear in both LabVIEW 7.1 and 8.0.  The USB camera did not appear (under LabView 8.0->RightClick on Blockdiagram->Functions->Vision and Motion->USB) until after I had ran VisUtil.exe.  It may be significant that I uninstalled Vision Development Module 7.1 and re-installed 7.1.1.  The directions for this operation and a reference to VisUtil.exe are here http://forums.ni.com/ni/board/message?board.id=200&message.id=8372.
(2,970 Views)
