NI-IMAQdx: (Hex 0xBFF69026) License not activated.
I want to use IMAQdx functions, but I receive "NI-IMAQdx: (Hex 0xBFF69026) License not activated." error. I have Vision Acquisition Software Feb 2014 which is activated. When I researched this error in this forum, I saw that it is a problem when the "Vision development module" and "Vision development module run time" exist together at the same machine. So, I tried to remove Vision Run-Time Engine from NI software, but I couldn't because of dependent products which are NI Vision ad NI Vision assistant. So  what am I doing wrong? What am I supposed to do?
Thanks.
Message 1 of 11
(6,609 Views)
You should be fine with just the Vision Acquisition Software...
Can you post a screenshot of your NI License Manager window?
Message 2 of 11
(6,605 Views)
Thanks for the reply
Message 3 of 11
(6,597 Views)
Interesting, it definitely appears compatible. This chart says the Vision Acquisition Feb-14 is compatible with LV 2010 - 2013SP1. Have you tried reinstalling/repairing VAS?
I am using LV 2014SP1 with VAS Aug-15 and it works fine. I also have an older (expired) version of vision development called Vision 7.1 installed.
Message 4 of 11
(6,590 Views)
I had the vision acquisition software(vas) 2016, but it was not compatible with my labview version. So recently I uninstalled vas 2016 and installed vas 2014 and so the IMAQdx functions appeared on the palette. But now I cannot use these functions because of this error, unfortunately.
Message 5 of 11
(6,574 Views)
Try right-clicking on both the VDM and the VDM Run-Time and choosing "deactivate."  After you do this, right-click only on VDM and choose "activate."  Activate JUST the VDM, close LV, reopen it.  Try again.  Does that behave any differently?
Message 6 of 11
(6,567 Views)
Hi natasftw,
I deactivated all the subproducts in VDM, then activated just the "vision development". Now I still receive the same error. Is Vision Run-Time means VDM-RT?
Message 7 of 11
(6,530 Views)
Yes.  The Vision Run-Time is the VDM-RT.  There isn't a RTE for the VAS drivers.  You just need to install the drivers for that.
Is your current state just the VDM is activated and the RTE is a white box?  I'm assuming you closed out of LV and tried to open it again after doing this.
If so, I'd take a look at uninstalling VDM from your control panel -> add/remove software -> national instruments -> VDM and installing it fresh.  You might even install it with the /reinstall flag to make it overwrite whatever is causing this strange problem to pop up.
Message 8 of 11
(6,504 Views)
I uninstalled and after installed VDM but nothing changed..
Message 9 of 11
(6,444 Views)
What is activated now?  Both or just the VDM?
Message 10 of 11
(6,423 Views)
