09-17-2017 10:01 PM
Hi
I am using a USB3 camera Pointgrey Flea3. I am trying to grab an image based on the external trigger received by the camera. However, I am finding the following error
Error-1074360293 occured at IMAQdx GetImage2.vi
Possible reason
NI-IMAQdx: Hex0xBFF6901B timeout.
This does not occur when I toggle the triggered acquisition to off on NI-MAX.
Could anyone please help.
Also, Please let me know what must be the settings on the NI-MAX.
Solved! Go to Solution.
09-18-2017
02:31 AM
- last edited on
12-13-2024
06:35 PM
by
Content Cleaner
Just looking at your issue and looking through the NI website I found this which suggests that it is your firewall. Did you consider that problem?
Anyway it's a timeout issue from the camera. So please check you installed drivers for it as well.
09-18-2017 09:14 AM
If it works in MAX and doesn't work in your LabVIEW code, it is probably your code. There is probably a missing wire, a missing function, an incorrect function, poor design, or some other flaw. Unfortunately, you failed to attach your VI (please do not waste our time by posting a picture of part of the Block Diagram)(but if your VI is part of a LabVIEW Project, feel free to compress the Folder containing the Project and attach the entire .zip file).
Bob Schor
09-18-2017 12:44 PM - edited 09-18-2017 12:51 PM
I am using Trigger and Grab.vi from the Labview examples. I am getting an error also in NI-Max. PLease help me with this.
Nachiket
09-18-2017 02:08 PM
When I try the examples with my cameras (where I don't see a Trigger Mode Attribute), I get error BFF6900F, Attribute not supported by the Camera. You are getting a TimeOut -- if we assume that the Camera supports a Trigger mode, this suggests you are not giving it a Trigger within the TimeOut window. This is not necessarily an error -- in your case, you set a timeout of 1 second, so a second after you start the Camera, if you don't give it a Rising Edge trigger, you should expect a TimeOut error (which you can choose to clear and ignore, perhaps looping until you do get a trigger).
Bob Schor
09-19-2017 08:29 PM
Thanks!!
