NI Lock in amplifier
I do not think it is a good idea. A lock in amp, requires simultaneous sampling. Your Daq unit is not such a device. Another question. Do you need a full Lock in amp, or just a phase sensitive detector.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 11 of 13
(1,251 Views)
thnks for your replay.i want  to lock the laser at 780nm.(This laser is External Cavity Diode Laser).Why it is not possible? here i decided to take the photodetector  output  throgh daq  , this output is multiplied with sinwave ..  and then pass through low pass filter. SO ITS OUTPUT IS DC.. i will get tis output through daq.and then it connected to ECDL.. this is my plan is it possible?
Message 12 of 13
(1,239 Views)
So you do not need the "lock in" part of a lock in amplifierA lock-in usually measures both in-phase (X) and out-of-phase (Y) components of the signal and can calculate the magnitude (R) from that. Do you need both the X, and Y components
Message 13 of 13
(1,236 Views)
