NI MAX APPCRASH after a random time of testcyclus
I am using LabVIEW and a PXI System with the following settings
LabVIEW.exe 2016 running with RUNTIME and developed by LV 2016 (32-Bit).
NI PXI-1033 Chassis with PXI-4065 (DMM) and PXI-2530 (Switch) connected over MXI.
Installation: RT 2016 (32-Bit), NI_DMM_DAQmx, NI_MUX_Switch, NI System Driver Set
Errordescription
After a random time of testcycle the SW isn´t able to test anymore. The results are NaN and basicaly the results should come out of the PXI and it shows the following errormassage:
"NI Device Monitor has stopped working"
Problemdescription:
Problem signature:
Problem Event Name: APPCRASH
Application Name: DeviceMonitor.exe
Application Version: 16.0.0.49152
Application Timestamp: 5750af16
Fault Module Name: clr.dll
Fault Module Version: 4.6.1590.0
Fault Module Timestamp: 5787ee4f
Exception Code: c0000005
Exception Offset: 004504cd
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: dff4
Additional Information 2: dff454251f7b75f4083787b774d04021
Additional Information 3: 4971
Additional Information 4: 4971f0678dfdd6a9be89bf679fa34257
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
I close the massage and the SW afterwards I try to open NI MAX.
It shows the following errormassage:
"Measurement & Automation explorer has stopped working"
Problemdescription:
Problem signature:
Application Name: NIMax.exe
Application Timestamp: 57430d64
Fault Module Name: nisysapi.dll
Fault Module Version: 17.0.0.49152
Fault Module Timestamp: 58a78d73
Exception Offset: 00075fae
Locale ID: 1033
Additional Information 1: d269
Additional Information 2: d269705a72866b2c4994edeff5f55a1c
Additional Information 3: 21f2
Additional Information 4: 21f2cd0866e68dcd50f73d5e56f4dafe
I close the message and restart the PC afterwards the SW is again working.
After 10, 100, 500 or sometimes 1000 testcycles appears the same problem.
The OS is Windows 7.
Many Thanks in advance
Best Regards
emsch
Message 1 of 1
(2,131 Views)
