NI MAX Calibrating Outputs
I've just been looking through NI MAX and am surprised to see that I can calibrate DAQmx inputs inside MAX, but not outputs?
Is there a reason for this that I can't see?
(3,298 Views)
Hi Lbee11,
I would suggest that the reason you can calibrate some things and not others is based on the device. Refer to the following article for information about this:
http://digital.ni.com/public.nsf/allkb/3FA6832D0124A4758625705B005981D8
Kind Regards,
Matt
(3,255 Views)
Maybe I should have been a bit more specific.
I have two DAQmx tasks, one that reads all Analog Inputs from a NI9209 c-series module and another task that writes outputs to a NI9263 c-series module.
When looking at the channel lines in NI MAX for each task, on the input task I have the option to calibrate each line individually. But for the Analog Output lines, there's no calibration feature. I can't see the "Self Calibrate" option either
(3,250 Views)
