NI MAX Remote system tree item not visible
I have LV2017 and NI MAX 17.5. I want to configure my cRIO but the NI MAX did not show the remote system tree item. I tried to uinstall all LV software based on one of the topic here but it did not help... lv.pnglv.png
(2,873 Views)
https://forums.ni.com/t5/LabVIEW/Remote-systems-missing-follow-up-to-other-post/m-p/1389934#M544193
Same Topic is discussed in the above thread, Hope that may help you.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,870 Views)
Accepted by topic author charlie87
thanks for your reply. In the end, my solution was simple, see the pic.
(2,841 Views)
