NI MIO Device Drivers 1.14.1 installation has failed.
I am trying to install DAQmx drivers, but everytime I get this error:
NI MIO Device Drivers 1.14.1 installation has failed. Continue?
It only happens in one computer (windows vista SP2 32 bits). I tried to use different versions of DAQmx but none of them work (same error). Because of that this computer can't detected a USB-6009 driver.
Any suggestion?
Thanks!
(4,100 Views)
Could you please let me know what versions of the DAQmx driver you have tried to install and attach a screenshot of your error?
Also, make sure you check here and here for driver compatibility.
(4,068 Views)
Hello
I have the same problem, I have an aplication with cDAQ-9174 and NI 9203 and NI 9421, When I install my aplication I had a message error, and the end I can run my aplication and I read the singnals in NI 9203 but I can't read the signals in my DI NI 9421.
What is the problem?
HELP
(3,939 Views)
I already Installed my aplication in a new computer with Windows 7 64 bits and it run perfectly, I developed my aplication in a computer with Windows 7 32 bits and LabVIEW 2009 32 bits, so I don't understand.
What I need to do?
(3,934 Views)
Hi Darth,
The error you are experiencing is a Windows MSI error.  Here is some more info on the windows installer software.  Also, what version of the DAQmx drivers are your using and what version of LabVIEW are you building an installer from? Are you using the same installer on both a 32 and 64-bit systems?
Mike Altmann
Product R&D
NI
(3,911 Views)
