NI Max 2020 wont run on Windows 10 after install
I am getting errors when trying to run NI Max 2020 after installing it on a windows 10 machine.  I have tried repairing it from NI Package Manager but it doesn't help. Also the NI configuration Manager service won't start, which I think is related.  Any suggestions other than a complete re-install?
Message 1 of 12
(2,954 Views)
It would make sense that the root of the problem is the service not starting.
On the last message, it says to look at the system event log.  Did you do that to see if there's anything in there with more information?
Message 2 of 12
(2,946 Views)
Windows event viewer message:
The NI Configuration Manager service terminated with the following service-specific error:
%%4294967295
I couldn't find anything helpful regarding this error code.
Ni system configuration version is 20.5.0
Ni Max version is 20.5.0
Ni DaqMx version is 20.7.0
Message 3 of 12
(2,847 Views)
When installing MAX, do you run it as a system administrator?
Message 4 of 12
(2,923 Views)
%%4294967295
Message 5 of 12
(2,851 Views)
It was installed by my IT dept, so probably yes.
Message 6 of 12
(2,913 Views)
Here is the event log message: The NI Configuration Manager service terminated with the following service-specific error: 4294967295
Message 7 of 12
(2,847 Views)
I'm trying to reply to your comment but my response keeps getting deleted. Not sure why. The event log message is: The NI Configuration Manager service terminated with the following service-specific error: %%4294967295
Message 8 of 12
(2,850 Views)
Try this:
Set these two services to auto/delayed:
I don't know why, but this seemed to help.  Believe it or not, McAfee was blocking them, but for some reason, if I delayed the start, McAfee let them be.  Maybe you'll have similar luck?
Bill
CLD
(Mid-Level minion.)
Message 9 of 12
(2,867 Views)
Reset Max DB.
Tools -> Reset configuration data
Qestit Systems
Certified-LabVIEW-Developer
Message 10 of 12
(2,814 Views)
