NI Measurement Studio UI components for Visual Basic 6.0 message box
Hey All,
North West Quality Analyst was recently installed on my LabVIEW development machine. Whenever I launch NWQA I get a dialog box to install "NI Measurement Studio UI Components for Visual Basic 6.0" for program called "Program Name."
I cancel out of the install and I can use NWQA just fine. However, I would like to eliminate the install attempt. Any ideas on how to do that?
I've tried to find the installer file on the Distribution discs, but on the two that I thought it would be on, "Measurement Studio Enterprise Support for Visual Studio 6.0" and "Measurement Studio Enterprise Edition" the file named "MStudioUIDemo.msi" was not found.
-Andrew
(3,879 Views)
Here is some information that could help us out. Hopefully you are using a WinNT variant (NT, 2000, XP). If so you can look in the Event Viewer.
Go to the Application section of the Viewer and look for a message like this:
MSI Error
Feature MStudio could not find component {26980287-C78C-4165-B49E-B65FBF29A253} attmepting reinstall.
We need to know that GUID.
Also we need to know what you have installed on your system from NI with versions (LabVIEW 6.1, CVI 7.0 , Measurement Studio 6.0, MAX 3.0, etc.)
This should help us figure out what is going wrong and how to solve your issue.
Jeff
NI
(3,871 Views)
Below is the text from the event viewer warning...
Detection of product '{7B0F253A-C7A2-4335-B041-99868E9EDEE8}', feature 'UI_Controls', component '{A44FC66B-252B-11D4-A77B-00104B6CE77D}' failed. The resource 'C:\WINNT\system32\CWHlpBtn.ocx' does not exist.
I have lots of stuff installed on the computer... MS Office, Codewarrior, Roxio, IE, MatLAB, etc.
Looking under MAX, I have the following NI software installed.
LabVIEW 6.1 (Advanced Analysis, Application Builder, Database Connectivity Toolset), 7.1 (Advanced Analysis, Application Builder), Runtime 6.0, 6.1, 7.0, 7.1, MAX 3.1.1.3003, NI-488.2 2.20, NI-CAN 2.2f2, NI-DSA, NI-IMAQ, NI-Motion, NI-PAL, NI-Switch, NI-USI, NI-VISA 3.2, Measurement Studio 6.0 (For Visual Basic(ActiveX User Interface, ActiveX 3D Graph, ActiveX DataSocket, ActiveX IMAQ))
The Dell box is running Window's 2000.
I found a listing under "Computer Management" -> System Information -> Software Environment -> Loaded Modules
that seems to have all the installed apps and such. I can send that to you privately if you desire.
-Andrew
(3,852 Views)
It looks as though the North West Quality Analyst program did not ship the help button with thier application as it shouldn't be shipped, but was probably not removed. If you would like I can send you the OCX to put into the system folder (it doesn't do anything and was used solely to help with Measurement Studio VB 6 Exmaples).
Please send me your email address and I will send you the OCX file.
Jeff
NI
If you would like to contact the people who created the North West Quality Analyst program, to let them know that they need to either remove the ActiveX control from their application or redistribute it using the Merge Module included with Measurement Studio. Or, you can have them contact us on this post and we can help them with any issues.
(3,841 Views)
What is your e-mail address?
(3,833 Views)
