NI OPC SERVER
hello, help, I have a problem, I can't start the NI OPC SERVER
I get the error "NI OPC Servers: Invalid or missing user information [data is corrupt]"
in the company's solution, it tells me to delete an xml file, I already did it, but now it says to reinstall the software in NI PACKAGE MANAGER, there I have the problem, I don't know what kind of software I should repair, I should repair the entire program labview or is there a specific file? Please, I would appreciate it if you could help me with this.
(2,249 Views)
John, I do not know the answer, but when in NI Package Manager after enabling the setting to show hidden packages, on the Installed tab if I type "opc" in the Search control and hit enter, I get three packages that somehow deal with OPC: DataSocket, NI OPC Support, and OPCEnum. Maybe selecting those 3 packages and select Repair might do what you want.
Scott Richardson
https://testeract.com
(2,228 Views)
wow, I'll try it, thank you very much for the information
(2,219 Views)
Hello, this step working to eliminate the error "Data is corrupt?"
(937 Views)
Hello Jhon, that advice working roght for you? i have the same problem.
(937 Views)
