NI OPC Server 2012 Adding Tags
When I launch the OPC Server Administration program, I must first disconnect from the runtime before I am able to add tags or groups to the current project.  When I'm done adding the tags, I save the project and reconnect to the runtime, however my changes dissapear and the project seems to revert to its original state.  I try reinitalizing the runtime and that has no effect.  Any ideas on why the changes I make aren't going into affect?
I last added tags to the server several months ago with no problem.  Nothing has changed with the hardware or software since then.  I'm quite stumped.
(3,492 Views)
Jeff@VMI,
This seems very strange. Have you tried doing a reinstall?
(3,459 Views)
