NI OPC server blocks LabVIEW instalation
We are trying to install LabVIEW 2024. Half way through the install  it reports an error:
An error occurred while installing a package: ni-opc-support (24.1.0.49350-0+f198)
Additional error information:
An error occurred while installing the MSI at 'opcsupp\opcsupp.msi'. Error 1321. The Installer has insufficient privileges to modify this file: C:\Program Files (x86)\National Instruments\Shared\Tagger\ni_tagger_plugin_OPCServer.dll.
Stopping OPC server in the system tray does not help.
(1,794 Views)
Try to kill tagsrv.exe manually from Task Manager before installation.
(1,752 Views)
There isn't a tagsrv.exe running in the memory. I tried stopping all the NI services  and closing tagger and opc related processes, but that did not help.
I tried changing permissions and ownership for the file and the folder, but I noticed that LabVIEW installer reverts the folder permissions to read-only and then reports folder write access error.
Was 2024 installer actually tested in house?
(1,742 Views)
I uninstalled all the NI software and tried installing LabVIEW 2023 Q1. I get OPC folder access error again:
An error occurred while installing a package: ni-opc-support (23.1.0.49273-0+f121)
An error occurred while installing the MSI at 'opcsupp\opcsupp.msi'. Error 1310. Error writing to file: C:\Program Files (x86)\National Instruments\Shared\Tagger\ni_tagger_plugin_OPCServer.dll. Verify that you have access to that directory.
(1,691 Views)
This happened to me. I ended up deleting the Tagger folder and this seemed to work for me. The folder was recreated during the install.
(1,531 Views)
