NI PCI-6259 rename
Hi
I am trying to run some code programed by other in my new computer. I got into the problem with th DAQmx create channel (AI-Votage-Basic).vi. It said that the identifier is invalide: it requires Dev2.
I try to change my DAQ to Dev but have problem renaming my NI PCI-6259 in MAX. I could not find any where to change its alias.
Message 1 of 14
(4,327 Views)
Did you right click the device and try to rename? Also check the "Data Neighbourhood" for the Task created for the Data acquisition.
Message 2 of 14
(4,314 Views)
There is no right click menuel for my NI PCI-6259. If I click Data Neighbourhood, it just keeps searching and never ends.
Message 3 of 14
(4,288 Views)
Which version of MAX are you using? and what is the LabVIEW version?
Message 4 of 14
(4,285 Views)
My MAX is NI System Configuration 5.6  and my LabVIEW version is 7.1
Thank you very much.
Message 5 of 14
(4,282 Views)
Are you an admin on the computer? You need to be.
Message 6 of 14
(4,278 Views)
Yes, I am. I can rename some other instruments, but not NI PCI-6259.
Message 7 of 14
(4,265 Views)
Can you remove the device and try to add it again and check? Is the card really present?
Message 8 of 14
(4,260 Views)
Are you getting a conflict when you are trying to rename this device? If yes, try this: http://digital.ni.com/public.nsf/allkb/FF9EEE0B28569617862573210073B69F
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 9 of 14
(4,227 Views)
Actually I am trying to run someone's code in a new computer, and I got an error at DAQmx Create Channel.vi. It said the device identifier is invalid (it used Dev2) . So I checked my MAX , but I could not find any alias for my NI DAQ as that in the old computer. I tried to find a way to change its name, but here is no response for right click.
Message 10 of 14
(4,239 Views)
