NI PCI 6515 DIO and NI PCI 4065 DMM cards configuration
 I am using NI PCI 6515 DIO card and NI PCI 4065 digital multimeter.I haven't any card yet and it will take some days to have them. I have installed these cards drivers. Is there any way that i can configure them in my software. I have added them virtually in MAX. Please suggest me possible ways i am using labview 8.5
timmy
Message 1 of 8
(3,981 Views)
I can see NI 6515 card in MAX devices and interfaces. That means its virtually added to device list. Now how can i use it in labview or where in labview i can find ni 6515 specific functions. Please guide me with ni 6515 and ni 4065 cards
timmy
Message 2 of 8
(3,970 Views)
Hi Timmy,
Both the PCI-6515 and PCI-4065 can be simulated in MAX. If you want to see examples of code for specific hardware you can go to the Help menu in LabVIEW, Find Examples, and in the bottom left hand corner choose the PCI-6515 or the PCI-4065 and check the Limit results to hardware box. This will narrow the examples to ones which can be used with the specific hardware.
Sunaina K.
Product Marketing Manager for CompactRIO & TSN
Making the intangible, tangible
Message 3 of 8
(3,954 Views)
Thanks Sunaina.
But I didn't found any examples regarding pci 6515 and 4065. I also searched C:\Program Files\National Instruments\LabVIEW 8.5\examples. I am uploading some screen shots may b am missing some steps. please help me with this
timmy
Message 4 of 8
(3,940 Views)
Hi Timmy,
It appears at there are no built in example for PCI-6515 and PCI-4065 for LabVIEW 8.5. If you go to ni.com/examples there should be a good starting point for the PCI-6515. Also, the NI Digital Multimeter Help manual goes into depth about program flow and the NI DMM VI's.
http://digital.ni.com/manuals.nsf/websearch/C857DCF0A0A5FD15862575A60080C18C
Sunaina K.
Message 5 of 8
(3,909 Views)
There are examples for the 6515 if you install the correct driver and look in the right place. You need DAQmx and look in the digital generation and digital measurements.
Message 6 of 8
(3,903 Views)
Thanks Sunaina once again and thanks Denis. Denis kindly take a look at pics i had uploaded. Is there any problem with my drivers
timmy
Message 7 of 8
(3,883 Views)
Yes. You do not have the DAQmx driver installed. Click on the support link at the top of the page.
Message 8 of 8
(3,879 Views)
