NI-PCI-6731
Can it still be used with LabVIEW 2012 and Windows 10?
I still have the old "LvDaq.dll".
(I wanted to use the card for tinkering because it has four fast outputs.)
(818 Views)
Hi Roth-Solms,
why don't you look for yourself?
You know that combination is not supported?
("Not supported" does not mean "it will not run", but "NI does not support/recommend this combination"…)
(781 Views)
Thanks for the link. Updates are running.
The last backup on a ZIP disk is from 2004. There's no record of how long the application was still in use with the PCI 6761.
Now we'll see what else works. I'll get back to you.
(733 Views)
