NI PCI-8512 - Blink on/off option disappeared in NI-MAX 19.5
Hello, as in the title, I can not find anymore the "Blink on/off" button on the interface page. Any clue? Thanks
(2,469 Views)
Accepted by topic author aRCo
Hi aRCo,
the Blink ON/OFF functionality for CAN interfaces is shipped with NI XNET, I'd suggest you check that the NI XNET are installed on your machine and that your device is supported by the NI XNET version you installed ("Hardware Section" of the NI XNET readme, see here for NI XNET 20.1).
If both XNET presence and hardware compatibility are present, I'd suggest to remove and reinstall the NI XNET drivers on your machine in order to compensate NI XNET drivers corruptions.
(2,402 Views)
Thank you
(2,300 Views)
