NI PCI-MIO-16XE-50 voltage output
I am an undergraduate student working on a research project. I need to program a labview block diagram to output continous voltage using DAQ NI PCI-MIO-16XE-50. I am new to this and having problems with formulating.
For example, if i need to output 4V, how to output 4V from the DAQ.
I know that there are 2 channels for output. But having problems figuring out which pins to use as well.
If there are any examples,tutorials or whatever hints i could get in order to solve this, that would be great. I am simply confused and wondering where to start.
Thanks in advance.
Confused undergraduate student
(2,529 Views)
Confused Undergraduate Student,
Dont worry, we have a huge amount of resources and tutorials available specifically for people in your situation.
For understanding pinouts, you can look in the user manual here:
https://www.ni.com/docs/en-US/bundle/370503k/resource/370503k.pdf
here is good getting started guide:
https://www.ni.com/docs/en-US/bundle/373737h/resource/373737h.pdf
We have many more resources available at NI.com. From there just use the search bar in the top right. Results can be sorted by type on the left.
Kyle Mozdzyn
Applications Engineering
Kyle M.
(2,507 Views)
Duplicate Post.
Please do not create multiple posts with the same question.  It caused two different people to try to help you at the same time thus duplicating their efforts.
(2,500 Views)
