NI PXI-1045 with MXI-4
I have a PXI-1045 chassis connected via a MXI-4 card to a Windows XP computer.
If I add a PXI card above slot number 12, a second PCI standard PCI-to-PCI bridge
driver is automatically (Plug and Play) installed. The first one is working okay.
This second one has error code 12 : this device has not enough free resources.
Because of this problem all the PXI cards above slot 6 are not visible in MAX,
and therefor unavailable. Does anyone know how to fix this problem ?
I disabled end enabled plug and play, disabled the audio device in BIOS, tried the
MXI-4 card in PCI slot number 1, 2 and 3, all this without any result.
(2,531 Views)
Hi Bartvsc
This could be a problem with the BIOS being unable to handle the resources behind a PCI-PCI Bridge. You could try and update your PC's BIOS which could improve the BIOS algorithms to better handle Nested PCI-PCI Bridges.
Karsten
(2,524 Views)
