NI-PXI 6509 simple question
I wonder if I could control an output port of a PXI 6509 device by
tristate property, i.e., has it got a configurable tristate output?
I know I must find it out by myself but, now, I am a newbie about this
device, DAQmx libraries are broken or corrupted (maybe, I have to
re-install Labview runtime) and it's not clear in the specs sheet.
Thanks in advance.
(2,865 Views)
jon ha escrito:
> Thanks in advance.
Ok, the answer is at
http://digital.ni.com/public.nsf/websearch/09B559BE292C75DB8625698500640E0A?OpenDocument
(2,861 Views)
Jon,
If you open the Add/Remove programs dialog in your control panel, you'll be able to repair the installation of your NI-DAQmx drivers by clicking on National Instruments Software.  Post back if that doesn't fix the issues you're having with the DAQmx libraries.
Elijah Kerry
NI Director, Software Community
(2,848 Views)
