NI PXI Switch
I need to work with an NI PXI switch, i.e I need to program it in LabVIEW. But I dont know how it works. I am looking for any material that helps with how the switching of relays of the switching matrix of the NI PXI switch works so that I can program it. It will be also good if I can see some sample LabVIEW programs of an NI PXI switch. Does anyone know online material that can help me learn and program an NI PXI switch.
Thank You
Govind
(2,382 Views)
You need NI Switch installed.  Once you have that installed, there are plenty of good examples through the LabVIEW Example Finder (Help->Find Examples) you can go through.
(2,362 Views)
