NI-PXIe-4357 and TBX-1303
I would like to know if I can connect a PXIe-4357 with the cable SH96-96 and TBX-1303 and gather data from a 2 to 4 wire RTD.  I know it is not the standard way of connecting to the module but it is what I have on hand.
Thank you,
Lisjwil
(1,464 Views)
Accepted by topic author Lisjwil
The instrument has a male 96-pin connector, the cable is 96-pin M-F and TBX-1303 has a male 96-pin connector.
From the images of connector on both 4357 and 1303, both are male, you would need F-F cable instead of M-F cable. There is no sufficient information easily available on the pin-out of 1303 to verify if the signals are mapped properly to 4357.
Santhosh
Soliton Technologies
(1,436 Views)
Hello Santhosh,
Thank you so much for your reply.  It turns out that the cable that I have has F/F so I could map try and map out the pins.  I was sort of asking the question in general, and I believe you have answered my question.
Lisjwil
(1,425 Views)
