NI-RFSG attributes
Is there a way to get the attributes from the RFSG?  I'm trying to use the NI-FGEN VI's and I cannot seem to find a way to extract the FGEN handle from RFSG VI's?
I can use the MT Get Attributes.vi to get to the NI-SCOPE instrument handle so I would like to believe there's a way to extract the FGEN handle from the RFSG.  Thanks.
- Eric
(2,704 Views)
Hello Eric,
There is a VI to do that, it is inside the RFSG LLB located usually at:
C:\Program Files\National Instruments\LabVIEW 8.2\instr.lib\niRFSG\niRFSG.llb\niRFSG Get Fgen Session.vi
Is there a special reason why you would like to use this handle that you were not able to do with RFSG driver?
Best,
Gerardo O.
RF SW Engineering R&D
(2,694 Views)
