NI Report and HTML printing
Here I have described a problem with the NI Report VIs and printing HTML report on different machines.
I have made a small app just printing a page with "Hello World" on it. This app was generated on my Windows XP Prof. SP 2 machine at home. My IE version is 6.2.2900.2180.xpsp_sp2_rtm.040803-2158 and the Active-X component used is shdocvw.dll version 6.2.2900.2180, 04.08.2004 13:00.
The archive contains the app and all sources in LV Version 8.2.
I want to know from you if this app will run on your machine. Please report if it did or not together with the information which OS you are using and which IE version you have.
It seems that this VIs want run reliably on all machines.
Thank you for all those who are reporting.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,111 Views)
It printed just fine on my machine.
Win XP SP2
IE 6.0.2900
LV 8.20 with the report generation toolkit installed for microsoft.
Joe.
"NOTHING IS EVER EASY"
(3,092 Views)
I have tested the app on 7 machines in the office. We have 4 LV installations were it worked and 3 which give error 1 in "Print HTML using IE.vi". 6 Installations are on XP Prof. SP2 and one is Windows 2000 SP4.
All XP machines should be the same because we have them generated from one image and we have a central system update here. I think I have to make a look to see any differences.
Waldemar
(3,075 Views)
