NI Robotics with D-Link IP Camera for Tennis Ball Tracker
Thank you for your reply and the link.
It is very useful but:
Please see attached screen shot from the error I have got.
It asks for imaq.dll
I used Max FTP to transfer the file
I found two of them with different size
1.69 MB on system32
and
1.4 MB under RT IMAGE
I tried to transfer one of them
but it gave error
Do you have an idea about the right way to transfer the file?
Pleasae read the error from the vi and correct me if I am wrong.
Many thanks in advance for your help and support.
Message 11 of 13
(795 Views)
1.69 MB on system32
and
but it gave error
Message 12 of 13
(795 Views)
Accepted by topic author Ihab
It sounds like the Vision Development Module Run-Time Engine (VDM RTE) needs to be installed on the Smart Camera (or the same version needs to be installed).
This white paper talks about installing the VDM RTE on the target machine. Essentially, the VDM RTE needs to be installed on the Smart Camera (right-click on the camera in MAX and select Add/Remove Software). See the last section as it talks about getting the VDM RTE on the target machine.
Bill E. | Applications Engineer | National Instruments
Message 13 of 13
(784 Views)
