NI SC-2345 pinout of SCC module
For the NI SC-2345
http://sine.ni.com/nips/cds/view/p/lang/en/nid/10778
Its intended to be used with SCC modules and not just really for direct analog inputs
but.
Is there a way to directly wire in the analog inputs (and gnd) without a SCC module?
No signal conditioning is needed, we just want to digitize the input.
So for example, on J1, which is where a SCC module could attach... there are 10 slots where a wire can be pushed in.
Which ones are gnds, analog inputs, etc?
(2,890 Views)
Hello Jimmy
You can find the device pin out in the device´s manual:
https://www.ni.com/docs/en-US/bundle/sc2345-2350-seri/resource/371064f.pdf
Take a look to pages B-1, B-2 and B-3
But the SC-2345/2350 carrier also has 42 screw terminals for direct connection to the DAQ device digital signals.
Regards
Mart G
(2,880 Views)
Hi Matt,
thanks for your reply.
Its always apprecaited.
the solution for this turned out to be get rid of the module break out box and just directly insert wires into to the scb  cable.
the pinout for that was easier to find
http://www.daqstuff.com/ebaydata/NI-CABLE-CATALOG-with-PINOUTS.pdf
(2,877 Views)
