NI Scan Engine, cRIO 9211 and CJC
Does anyone know if the temperature returned by the scan engine uses the CJC and zero offset channels on the 9211?
(3,905 Views)
Hi sachsm,
The Scan Engine will return calibrated data, so it should already have incorporated the CJC and zero offset channels.
Jeremy_B
(3,879 Views)
Yes, I agree that it should, but does it actually?
(3,875 Views)
Yes, it does.
JMota
National Instruments - R&D
(3,868 Views)
Just to clarify.
Is the CJC based on a constant temp(25 degress C) or is it measured using a isotermic bloc in the module itself when using the Scan Engine?
AMeister
(3,648 Views)
This is what the 9211 user manual says about it.
http://digital.ni.com/manuals.nsf/websearch/A24B9BB284234EDF862571CA00684AC7
Heat dissipated by adjacent modules or other nearby heat sources
can cause errors in thermocouple measurements by heating up the
terminals so that they are at a different temperature than the
cold-junction compensation sensor used to measure the cold
junction.
Not sure what the different ways for implementing CJCs are, but is there something that can be inferred by knowing that is a an actual sensor within the module?
(3,639 Views)
