NI Scope FFT frequency shift
I use a DAC card (NI PXI/PCI-5401) to generate a sinus and a ADC card (NI-PCI-5911) to pickup this sinus. To transform the time domain sinus signal into a frequency domain signal, I have used an example of NI using the NI-Scope vi "Add process" with FFT.   Somehow, the sinus generated at 50kHz is shown in the frequency domain at a frequency of approximately 58kHz. I don't understand this shift. Would you have an idea? Both vis used are attached
Best,
Ninskaya
(2,918 Views)
Hi Ninskaya!
What happens if you try higher or lower frequencies?
Hendrik
Message Edited by Honsel on 05-30-2006 08:24 AM
(2,901 Views)
Hi Henrik,
Thank you for your help. Actually, I had programmed a sinus with a sample rate, which was lower than the one of the card. After changing this, the shift disappeared. Thanks again.
Ninskaya
(2,889 Views)
