NI Scope configure vertical timing
Hello. I hope this is a right place to ask my question.
I quite new to LabView and now trying to understand the NI-Scope initialization procedure. In vertical timing VI, there is min record length. if my minimum sampling rate is 2 MHz and min record length 14000000, does it mean that 14000000 samples will be recorded per second? And the sampling period is 0.5 us?
Thank you
(1,142 Views)
Hi Lily,
A sample rate of 2MS/s means a sample period of 0.5µs. And it means 2 million samples per second.
A record length of 14M samples means time = (number of samples) / samplerate = 14MS / 2MS/s = 7s…
(1,137 Views)
I believe you mean Horizontal Timing and the Vertical axis is typically volts/div...
If you consider a typical oscilloscope has 10 divisions on the Horizontal scale:
Record Length =  Time/div (seconds) * Sample Rate * 10 (divisions)
=== Engineer Ambiguously ===
(1,135 Views)
Hello. I am a bit confused with this block  niScope Configure Horizontal Timing specifically with min record length. Can someone explain how it is determined and how it workds? Thank you
(1,083 Views)
(1,046 Views)
