NI Service Locator on RT systems?
Note: Theoretical query since no RT hardware available for testing this.
I know the NI Service Locator is a Windows service that maps Service Names to port numbers for UDP/TCP for NI products. Is there a sister service that runs on the RT systems and do they speak with each other to synchronize port numbers of same-named services? UDP packets contain port numbers, not service names.
In other words, if I specify a UDP connection to a RT app with my own special ServiceName on a Windows host app, will the RT app connect to that ServiceName/port if the RT app was listening on a UDP connection opened with the same ServiceName? The examples reviewed used hard-coded port numbers and the Named-Service example ran completely on the Windows side. One might ask why would I want a Named-Service associated with an RT app, well, remember...theoretical and also to allow the OS to pick the port used.
My primary RT experience is with FieldPoint (6.0.6 & 6.0.9) and no such labeled modules were listed in the cdf files (\Program Files\NI\RT Images\FieldPoint Predefined Software Sets\<version>) unless it is now included with Web Services (as indicated for LV2010).
(2,539 Views)
I've tried using the connection by service name before (as have some colleagues of mine) and it never seemed to work with RT,
I may be remembering wrong, but I don't even think that I got it to work from one computer to another (only on the local machine).
Chris
Certified LabVIEW Architect
Certified TestStand Architect
(2,534 Views)
