NI Service Manager Always loads at Startup
I'm using LV 7.0 Express (newbie). Every time I boot now, a TSR called "NI
Service Manager" loads and presents an Icon in the system tray. When I'm
not doing LabView, I right click, and select "Quit Service Manager". Do I
need this service manager for GPIB functions with LV?
Can I set it up so NI Service Manager only loads when I'm doing LV? Thanks!
remove antispam ??? to reply or post here.
(4,088 Views)
I am not using any of the NI Services, so I just deleted the Service Manager from the "Start Menu\Programs\Startup" folder.
-Jim
(4,087 Views)
Please refer to this KnowledgeBase document for more information about disabling the NI Service Locator and what will happen if you do so: What Network Activity is LabVIEW Performing at Startup?
For example, you will not be able to click buttons in the LabVIEW Help to place VIs, functions, and constants on the block diagram. Also, you will not be able to open VIs from the NI Example Finder.
Kelly H
LabVIEW Documentation
(4,087 Views)
Requirements    Price: $29.95
 Application Software:
LabVIEW 7.0+
 Toolkits Software:
 Additional Software:
 Language's:
INVtray LabVIEW Toolkit allows the programmer to create a LabVIEW program that can be hidden from the task bar and accessed through the System Tray.  Comes with a sample VI that demonstrates all the features of the toolkit.
(3,971 Views)
