NI System Configuration APIs -> Init session -> Error nierinterface.dll
i tried to use the VIs from the system configuration api:
http://zone.ni.com/reference/en-XX/help/373107E-01/nisyscfg/initialize_session/
When i start my VI or if i try to open the VIs "init session" i got the message
System Error
nierInterface.dll is missing.
Reinstall the software.
Google Search "nierinterface.dll" -> 0 resulst
NI Forum Search "nierinterface.dll" -> 0 results
Can someone tell what DLL that is? How should I find it, when google doesn't know that 🙂 Very funny 🙂
(10,848 Views)
Hi sjunge,
it seems that something went wrong during the installation process.
Which version of LabVIEW and which drivers are you using?
First I would try to reinstall the NI System Configuration you can finde it here:
Downloads
Just search for "NI System Configuration". When choosing the version be sure to select a download which is compatible with the rest of your Software.
If reinstalling the NI System Configuration Tools don't work, I would recomment to do a reinstall / update of LabVIEW and the Drivers you need.
Ensure that you have admin rights and that you deactivated virus scanners or firewalls so they can't interfere during the installation process.
Best Regards,
Lam
(10,813 Views)
