NI USB 6008 - Analog Output
Hello All,
I'm trying to get a Softwaretimed waveform at the output of my 6008. To do so I'm using one of the Example VI's shipped with LabView (see attachment).
So far so good, it does generate a Software timed signal and I can even vary the frequency. The problem is: the generated sinewave is centered at zero which means that only the first half of the wave is reproduced at the output (because the device works only between 0 and +5V) and the first negative value causes an error.
I want to stick a DC Offset to the generated waveform - so that the whole wave stays above zero - but haven't been able to do so.
Can anybody help and explain to me what has been done?
Thanks in advance...
Roberto
(2,905 Views)
Oh, I forgot to attach the VI!
Here it goes...
(2,905 Views)
To add an offset to an array, add the offset.Smiley Very Happy
Message Edited by Dennis Knutson on 03-08-2007 07:28 AM
(2,898 Views)
