NI USB-6008 NO DETECTA ENTRADAS NI SALIDAS FISICAS
Buen dia,
Tengo una tarjeta NI USB-6008 SN. 12AC50C desde el 2007. Instale la unica version disponible NI-DAQmx 2022 Q3.
Usando el NI MAX, la tarjeta aparece en "Devices and Interfaces" como: (NI USB-6008 "USB\VID_3923&PID_717A\012AC50C") y dice en "status" que está presente.
Voy a "Data Neighborhood" con clic derecho y "Create New". Estando en esta ventana, escojo "NI-DAQmx Task" y cuando quiero generar o adquirir una señal, en "Physical-Supported Physical Channels" aparece un mensaje que no encuentra ningun dispositivo soportado estando la tarjeta conectada a usb. Intente con Labview generar una señal y aparece que no encuentra ningun dispositivo soportado.
Ayuda para poder usar mi tarjeta de forma optima y continuar con mi proyecto.
GRacias
Cordialmente,
JUan Gabriel Mazuera
Message 1 of 11
(1,664 Views)
Hello Juan,
this is an english speaking (writing) community. The chance to get an answer is much bigger, if you write your question in english. If you think it is too difficult to translate your question yourself, try the very good tool www.deepl.com/translator.
These are my two cents...
Greets, Dave
Message 2 of 11
(1,624 Views)
Excuses. Here in English:
Good morning,
I have a NI USB-6008 SN. 12AC50C since 2007. I installed the only available version NI-DAQmx 2022 Q3.
Using NI MAX, the card appears in "Devices and Interfaces" as: (NI USB-6008 "USB\VID_3923&PID_717A\012AC50C") and says in "status" that it is present.
I go to "Data Neighborhood" with right click and "Create New". Being in this window, I choose "NI-DAQmx Task" and when I want to generate or acquire a signal, in "Physical-Supported Physical Channels" appears a message that it does not find any supported device while the card is connected to usb. I tried with Labview to generate a signal and it appears that it does not find any supported device.
Please help me to use my card optimally and continue with my project.
Thank you
Cordially,
Message 3 of 11
(1,611 Views)
USB-6008 is supported by DAQmx 2022. Please share a screenshot of your NI MAX listing USB-6008. It will be worth to disable all Antivirus and Firewalls to see if that caused any issues.
Santhosh
Soliton Technologies
Message 4 of 11
(1,605 Views)
The antivirus and the windows defender firewall are disabled.
I attach the screenshots and waiting for a help.
Message 5 of 11
(1,599 Views)
Hi Juan,
that USB6008 should NOT be shown as "USB/…", but as "Dev0" instead!
So MAX sees there's a device connected, but it seems it misses the DAQmx drivers needed to really communicate with your USB DAQ device!
Did you really install all needed DAQmx drivers/packages?
Message 6 of 11
(1,592 Views)
Try manually forcing Windows to reinstall drivers in Device Manager.
Go to Device Manager, select the USB-6008 device, select update device driver, search local folders, and select the C:\Windows directory, hopefully, Windows will now use DAQmx drivers.
Santhosh
Message 7 of 11
(1,582 Views)
I used the daqmx 2022 Q3 that is in the ni web.
Do you have the packages to install?
Good day
Message 8 of 11
(1,575 Views)
Thanks, but it didn´t work.
Please help me with the softwares that I need to install the NI USB-6008 works properly
Message 9 of 11
(1,548 Views)
Please help me with the softwares that I need to install the NI USB-6008 works properly.
Help me with links and versions I must install.
I installed the labview and then installed NI DAQmx 2022 Q3 that is in the NI support web.
Message 10 of 11
(1,547 Views)
