NI USB 6008 and generation of waveform
hi everyone , i'm working on a project using the NI USE 6008 and i want to generate a waveform ( sinus ..) is there any solution please ?
(3,052 Views)
Hi alias,
LabVIEW (and the DAQmx device driver) comes with a lot of example VIs. There you will find examples on how to output a sine wave on your USB6008. (You can filter by hardware in the example finder.)
Read the specs of your rather cheap DAQ hardware: it allows on it's AO channels only upto 150S/s and no hardware timing…
(3,045 Views)
