NI USB 6008 , help needed
Hi
I would like to use NI USB 6008 for a small project.actually when i read the driver comparison i got some doubts.
1)is it possible to log voltages continuously ,
2)since multi threading i/o feature will it affect to my code.
3)in a single programme iwanto acquire voltages from 2 channels that will continuously updating like
0-0.5v-1.0v.........and to operate the digital outputs is it possible to build such applications.
the driver comparison http://www.ni.com/dataacquisition/companion_software.htm
Regards
Thanks in advance
rajesh
(2,806 Views)
How fast are you trying to measure the data, samples/sec., and how fast do you need to update your output signals?
What are your concerns regarding the driver comparison?
Putnam Monroe
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,797 Views)
