NI USB 6009 error voltage measurement
Hello community,
I am new to this forum and have a question about the error associated with voltage measurements. I did a couple of voltage measurements with the data aquisition card NI USB 6009 (Analog input, RSE) and now want to calculate the error in these measurements to add error-bars in my thesis. Unfortunately I'm not able to find any data in the user manual of the data aquisition card as how large the error is (the only information I find is the resolution, 13bit)
Does anybody of you know how to calculate the error here ?
Any ideas leading to the solution are appreciated 🙂
Best regards
Ch33rs
(1,615 Views)
Accepted by topic author ch33rs
Hi ch33rs,
When I google for "usb6009 datasheet" then several links to PDF files are presented...
Read the datasheet, especially table 1 and 2!
(1,587 Views)
Wow, seems like I just didn't find the table ^^
Thank you very much
(1,576 Views)
