NI USB 8452 excessively long program execution time
Hi, I have a LabView program that uses NI USB-8451/2 and sends SPI commands to a slave device repetitively in a loop. I want the program to have as short iteration time as possible, to be able to re-program slave device fast.
The NI-USB 8452 have an excessively long execution time of 1000+ ms. This is not a complicated program, no converging algorithms or anything similar, just simple calculations and register write/read. For comparison, the same program on the older NI-USB 8451 takes 20-30 ms to run.
Also, i noticed that execution time on 8451 gets longer and longer as more iterations are done (after thousands of iterations time reaches 300-400 ms , from initial 20-30). There are no self-appending variables. All the variables are re-assigned on the start of new iteration.
What's the issue? The SPI runs with 10 MHz clock and wirtes/reads 11 32-bit registers, so the programming time should not take longer than hundreds of us.
The program uses formula nodes for simplicity.
I would be grateful for any help.
Regards
(3,128 Views)
@GSnawadzki wrote:
What's the issue?
Impossible to say without seeing the code.  But my first thought is you are not handling references properly.
(3,107 Views)
Hello crossrulz, thank you for your reply.
According to:
https://forums.ni.com/t5/LabVIEW/reference-vs-local-variable/td-p/1781924
and
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LXrSAM&l=pl-PL
I am not using references nor property nodes. Only direct wire or local variable, because they are faster.
Unfortunately, I cannot show the code (it's my employer's property) 😕
Regards
PS. I'm also a fan of Monty Python and the Knights of NI 😄
(3,085 Views)
I was actually referring to the reference to the 8452.
Then make a small example that is showing the issue.
Knight of NI is actually a community ranking for those who manage to rack up 10k posts.  Though, the term was created by Dennis (the original knight) who was a HUGE Monty Python fan.
(3,081 Views)
Here is the thread from 16 years ago when we were figuring out what the top ranking should be.
Ben
(3,073 Views)
