NI USB6008 DAQ module, AD595 and Polynomials
I am trying to linearise an output from a thermocouple, using the configuration on a DAQ input. The equipment involved is a NI USB6008 DAQ module, a type K thermocouple, and an AD595 amplifier. The data I’ve used is NIST polynomials, which I have typed into the input configuration. Before typing in the data I had a value for temperature which was in the right area, 18C. After entering the polynomial data I have a value of -10C.
Now where I may be going wrong is that the output from the AD595 is 10mV/C where the Thermocouple sensitivity is 41µV/C a gain of 245. I’ve tried scaling the polynomials, but same incorrect output. Any Idea where I’m going wrong?
(3,540 Views)
Can you post what you're doing? Show us the code? Is what you have done so far in LabVIEW or in MAX (Measurement and Automation Explorer)?
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,533 Views)
Without looking at your code it is hard to say.  I do have some experience with the AD595, and I found that if you crank up the gain too high it becomes more and more non-linear...  I also remember the AD595 not working well with grounded thermocouples... but it may have just been my interface circuit.
(3,509 Views)
Hi
The code is a simple test code to evaluate the effect of linearising with polynomials. Find attached screenshots.
Many thanks for your reply
George
(3,501 Views)
Did you read the section in the AD595 datasheet on interpreting output voltages?  It specifically mentions an offset voltage of -11 uV.
Lynn
(3,468 Views)
Hi
I have attached the simple test code I used to evaluate the effect of applying the polynomials. The value without the polynomials in the scaling is where you would expect around 20 C, with the polynomials -447C.
George
(3,462 Views)
I cannot help with that as I do not have the DAQ stuff.
Lynn
(3,454 Views)
