NI USRP 2900 Device Name not showing
Hi to all
i have a problem while using NI USRP 2900.
my professor gave me USRP-2900. i have tried every thing to just keep it working but unable to start it. The device name doesnot appear in any VI. how to run basic USRP Program on it.
Kindly tell me what should install and what not
Previously i have installed Labview 2017, USRP 17, LABVIEW 2015, USRP 16, USRP 15 but have the same problem.
i want to use it on LABVIEW. dont want to use Communication suite. do anyone know how could run on LABVIEW
Regards
Ali
(3,597 Views)
Hi!
Just to confirm, you are currently using LabVIEW 2017 and NI-USRP 17.0? You can double check that is what you currently have installed by opening NI-MAX, and navigating to the "Software" menu on the left.
Do you have another USRP 2900 you can try on your system?
(3,520 Views)
Accepted by topic author usrp_guy_16
Can you try "NI2900" in the Device Name ?
Regards
(3,513 Views)
