NI USRP 2920
Hi everyone,
I am running a 2x2 MIMO system using Alamouti coding based on a LabVIEW example from the NI website (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2rKCAQ&l=en-IN). However, when executing the main program, I encounter the following error:
niUSRP Write Tx Data (2D CDB).vi Packet had timestamp that was late (or too early).
Upon further investigation, I traced the issue to the SubVI subAsyncMulti-ChannelTransceiver(NIUSRP).vi, where I found the following error:
niUSRP Configure Number of Samples.vi The specified session handle is invalid or does not correspond to an active session.
Has anyone encountered this issue before or can provide insight on how to resolve it?
Message 1 of 1
(391 Views)
