NI USRP-2952R : GPS antenna
Q1) NI USRP-2952R 사용자입니다.
안테나 "panasonic vic 100 gps antenna"를 결합하여 Labview를 통해 성능을 파악해보고 싶은데, 어떻게 해야 하나요?
Q2) labview를 통해, gps의 성능을 파악하는 예제가 따로 있나요?
eng)
Q1) I am User of NI USRP-2952R.
I want to use the antenna "panasonic vic 100 gps antenna" to understand the performance through Labview, what should I do?
Q2)
Is there another example of how to understand the performance of gps antenna through labview?
(1,551 Views)
Accepted by topic author harrykim123as
I am User of NI USRP-2952R. So I bought "5V GPS Antenna" for testing.
I want to know about spec "5V GPS antenna" or labview file. how to get it?
(1,564 Views)
I was confused about how to use the program "LabView" & GPS Antenna.
But it has been solved.
https://youtu.be/Dmy4EFJfVSs
(1,439 Views)
